Mesh Boolean Node
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
Inputs – Уводи
- Mesh 1/2
Standard geometry input.
- Self Intersection
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
- Hole Tolerant
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Properties – Властивості
- Operation – Операція
- Intersect – Перетин
Produce a new geometry containing only the volume inside of both geometry 1 and geometry 2.
- Union – Об’єднання
The two input meshes are joined, then any interior elements are removed.
- Difference – Різниця
Geometry 2 is subtracted from geometry 1 (everything outside of geometry 2 is kept).
Вивід – Output
- Mesh – Сіть
Standard geometry output.
