Mesh to Points Node
The Mesh to Points node generates a point cloud from a mesh.
Inputs – Уводи
- Mesh – Сіть
Standard Mesh input.
- Selection – Вибрання
The meshes used to generate a point cloud.
- Position – Позиція
Positions of generated points. By default, this input is the same as if the Position Node was connected.
- Radius – Радіус
Radii of generated points.
Properties – Властивості
- Mode – Режим
- Vertices – Вершини
Points are generated for each vertex.
- Edges – Краї
Points are generated for each edge, at the middle of each edge, by default.
- Faces – Грані
Points are generated for each face, at the average of all of each face’s vertices, by default.
- Corners – Кутки
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Outputs – Виводи
- Points – Точки
Generated point cloud.
