Set Shade Smooth Node
The Set Shade Smooth node controls whether the mesh’s faces look smooth in the viewport and renders. The input node for this data is the Is Shade Smooth node.
Inputs – Уводи
- Mesh – Сіть
Standard geometry input.
- Згладжене Відтінення – Shade Smooth
When true, the selected faces will be marked to render smooth shaded. Otherwise the faces will be rendered flat shaded.
- Selection – Вибрання
Boolean input for selecting which faces will have the Shade Smooth value applied.
Properties – Властивості
Outputs – Виводи
- Mesh – Сіть
Standard geometry output.
