Sample Index Node
The Sample Index node retrieves values from a source geometry at a specific index.
Порада
If the Geometry used for the input is the same as the geometry from the field context, this node is equivalent to the Field at Index Node. Using that node is usually preferrable since avoding the geometry socket makes the whole setup easier to use in other situations and share.
Inputs – Уводи
- Geometry – Геометрія
The geometry to retrieve the attribute from.
- Value – Значення
A field to evaluate on the source Geometry. The values are then retrieved from specific indices for the output.
- Index – Індекс
Which index to use when retrieving the data from the input Value field. Any index can be connected, resulting in a «shuffling» of the values.
Properties – Властивості
- Тип Даних – Data Type
The data type to use for the retrieved values.
- Домен – Domain
The attribute domain that the attribute is transferred from, or in other words, the domain used to evaluate the Attribute input. For example, it is possible to transfer data from the faces of one geometry to the points of another.
- Clamp – Затиск
Clamp the indices to the size of the attribute domain instead of outputting a default value for invalid indices.
Outputs – Виводи
- Value – Значення
The data retrieved from the source Geometry input.
Examples – Приклади
Here the node is used to copy the positions of one object to another. This recreates the behavior of the Transfer Attribute node from Blender versions before 3.4. This works best when their geometries have the same number of points and the same Topology.
