Nút Thông Tin đối tượng (Object Info Node)
The Object Info node gives information about the object instance. This can be useful to give some variation to a single material assigned to multiple instances, either manually controlled through the object index, based on the object location, or randomized for each instance. For example a Noise texture can give random colors or a Color Ramp can give a range of colors to be randomly picked from.
Đầu Vào (Inputs)
Nút này không có đầu vào.
Tính Chất (Properties)
Đầu Ra (Outputs)
- Địa Điểm (Location)
Vị trí của đối tượng trong không gian thế giới.
- Màu Sắc (Color)
Object color, same as Color in the .
- Alpha
The Alpha Channel component of the object's viewport display color (see the Color output for more details).
- Chỉ Số Đối Tượng (Object Index)
Object pass index, same as Pass Index in the .
- Chỉ Số Nguyên Vật Liệu (Material Index)
Material pass index, same as Pass Index in the .
- Ngẫu Nhiên (Random)
Random number unique to a single object instance.
Ghi chú
Note that this node only works for material shading nodes; it does nothing for light and world shading nodes.
Ví Dụ (Example)
