Nút Thông Tin về Hạt (Particle Info Node)
Duy Cyles (Cycles Only)
The Particle Info node can be used in the material node tree for objects that are used as the instancing objects, when you use Object or Group Render mode of a particle system.
This node gives access to the data of the particle that spawned the object instance. It can be useful to give some variation to a single material assigned to multiple instances of instancing object.
Ghi chú
This node currently only supports parent particles. Info from child particles is not available.
Đầu Vào (Inputs)
Nút này không có đầu vào.
Tính Chất (Properties)
Đầu Ra (Outputs)
- Chỉ Số (Index)
Index number of the particle (from 0 to number of particles).
- Ngẫu Nhiên (Random)
A random per-particle value in the range from 0 to 1. It can for example be used in combination with a color ramp, to randomize the particle color.
- Tuổi thọ (Age)
Age of the particle in frames.
- Tuổi Thọ (Lifetime)
Total lifespan of the particle in frames.
- Địa Điểm (Location)
Vị trí của hạt.
- Kích Thước (Size)
Kích thước của hạt.
- Tốc Lực (Velocity)
Vận tốc của hạt.
- Vận Tốc Góc (Angular Velocity)
Vận tốc góc của hạt.
