Nút Thông Tin Đường Cong (Curves Info Node)
Nút Thông Tin Đường Cong.
The "Thông Tin Đường Cong" node gives access to Tóc/Lông (Hair) information.
Đầu Vào (Inputs)
Nút này không có đầu vào.
Tính Chất (Properties)
Đầu Ra (Outputs)
Là Sợi (Is Strand)
Outputs 1 when the shader is acting on a strand, otherwise 0.
Điểm Giao Cắt (Intercept)
The point along the strand where the ray hits the strand (1 at the tip and 0 at the root).
Chiều Dài (Length)
The total measurement from the root to the tip of the strand, interpreted as a grayscale value from 0 to infinity.
Độ Dày (Thickness)
The thickness of the strand at the point where the ray hits the strand.
Pháp Tiếp Tuyến (Tangent Normal)
Pháp tiếp tuyến của sợi.
Ngẫu Nhiên (Random)
A random per-curve value in the range from 0 to 1. It can for example be used in combination with a color ramp, to randomize the curve's color.
