拆边¶
Like the 拆边修改器, the Edge Split node splits and duplicates edges within a mesh, breaking 'links' between faces around those split edges.
Note
Splitting edges effectively breaks the mesh topology.
输入¶
- 几何数据(Geometry)
Standard geometry input.
- 边夹角
启用该选项时,如果棱的邻接面的二面角大于 分离角度 ,棱将会分离开。
- 角度
On 0: all edges are split. On 180: no edges are split.
- 锐边
When enabled, edges will be split if they were marked as sharp.
属性¶
这个节点没有属性。
输出¶
- 几何数据(Geometry)
Standard geometry output.
