表面细分(Subdivision Surface)
../../../_images/modeling_modifiers_nodes_subdivision-surface.png
Subdivision Surface Node.
The Subdivision Surface node deform the geometry using Catmull-Clark deformation.
输入
几何数据(Geometry)
Standard geometry input.
水平
To which degree the geometry will be deformed.
折痕
Control how smooth edges should be with 加权边折痕.
边界平滑
Controls if open boundaries and corners are smooth.
Smooth UVs
Controls if subdivision smooth is applied to UVs.
属性
这个节点没有属性。
输出
几何数据(Geometry)
Standard geometry output.
