Mesh to Points Node
![Mesh to Points node.](../../../_images/node-types_GeometryNodeMeshToPoints.webp)
The Mesh to Points node generates a point cloud from a mesh.
輸入
- Mesh
Standard Mesh input.
- Selection
The meshes used to generate a point cloud.
- Position
Positions of generated points. By default, this input is the same as if the Position Node was connected.
- Radius
Radii of generated points.
屬性
- Mode
- Vertices
Points are generated for each vertex.
- Edges
Points are generated for each edge, at the middle of each edge, by default.
- Faces
Points are generated for each face, at the average of all of each face's vertices, by default.
- Corners
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
輸出
- Points
Generated point cloud.
