Split Edges Node
![Split Edges node.](../../../_images/node-types_GeometryNodeSplitEdges.webp)
Like the Edge Split Modifier, the Split Edges node splits and duplicates edges within a mesh, breaking 'links' between faces around those split edges.
輸入
- Mesh
Standard geometry input.
- Selection
A standard Boolean selection input to determine which edges will be split.
Note
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
屬性
這個節點沒有屬性。
輸出
- Mesh
Standard geometry output.
