Set Shade Smooth Node
![Set Shade Smooth node.](../../../_images/node-types_GeometryNodeSetShadeSmooth.webp)
The Set Shade Smooth node controls whether the mesh's faces look smooth in the viewport and renders. The input node for this data is the Is Shade Smooth node.
輸入
- Mesh
Standard geometry input.
- Shade Smooth
When true, the selected faces will be marked to render smooth shaded. Otherwise the faces will be rendered flat shaded.
- Selection
Boolean input for selecting which faces will have the Shade Smooth value applied.
屬性
這個節點沒有屬性。
輸出
- Mesh
Standard geometry output.
