FBX¶
Referenz
- Kategorie:
Import-Export
- Menü:
Add-on aktivieren¶
This add-on is enabled by default, in case it is not:
Öffnen Sie Blender und gehen Sie zum Abschnitt Add-ons der Benutzereinstellungen Preferences (Einstellungen).
Search „FBX“ and check the Enable Add-on checkbox.
Nutzung¶
This format is mainly use for interchanging character animations between applications and is supported by applications such as Cinema4D, Maya, Autodesk 3ds Max, Wings3D and engines such as Unity3D, Unreal Engine 3/UDK and Unreal Engine 4.
The exporter can bake mesh modifiers and animation into the FBX so the final result looks the same as in Blender.
Bemerkung
Bones would need to get a correction to their orientation (FBX bones seems to be -X aligned, Blender’s are Y aligned), this does not affect skinning or animation, but imported bones in other applications will look wrong.
Animations (FBX AnimStacks, Blender actions) are not linked to their object, because there is no real way to know which stack to use as ‚active‘ action for a given object, mesh or bone. This may be enhanced to be smarter in the future, but it’s not really considered urgent, so for now you’ll have to link actions to objects manually.
Armature instances are not supported.
Bemerkung
Bones‘ orientation importing is complex, you may have to play a bit with related settings until you get the expected results.
Animation support is minimal currently, we read all curves as if they were ‚baked‘ ones (i.e. a set of close keyframes with linear interpolation).
Imported actions are linked to their related object, bone or shape key, on a ‚first one wins‘ basis. If you export a set of them for a single object, you’ll have to reassign them yourself.
Bemerkung
Saving Just Animations
The FBX file format supports files that only contain takes. It is up to you to keep track of which animation belongs to which model. The animation that will be exported is the currently selected action within the Action editor. To reduce the file size, turn off the exporting of any parts you do not want and disable All Actions. For armature animations typically you just leave the armature enabled which is necessary for that type of animation. Reducing what is output makes the export and future import much faster. Normally each action will have its own name but the current or only take can be forced to be named „Default Take“. Typically, this option can remain off.
Bemerkung
Blender now only supports complex node-based shading. FBX having a fixed pipeline-like support of materials, this add-on converts between them.
Eigenschaften¶
Importieren¶
Include¶
- Import Normals
Zu tun
Add this information.
- Import Subdivision Surface
Import FBX subdivision information as subdivision surface modifiers.
- Import User Properties
Import user properties as custom properties.
- Import Enums as Strings
Store custom property enumeration values as strings.
- Image Search
Zu tun
Transform¶
- Scale
Value by which to scale the imported objects in relation to the world’s origin.
- Decal Offset
Zu tun
- Manual Orientation
Zu tun
- Forward / Up Axis.. todo:: Add this information.
Since many applications use a different axis for ‚Up‘, these are axis conversion for these settings, Forward and Up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
Blender uses Y Forward, Z Up (since the front view looks along the +Y direction). For example, its common for applications to use Y as the up axis, in that case -Z Forward, Y Up is needed.
- Apply Transform
Zu tun
- Use Pre/Post Rotation
Zu tun
Animation¶
- Animation Offset
Offset to apply to animation timestamps, in frames.
Armature¶
- Ignore Leaf Bones
Ignore the last bone at the end of each chain (used to mark the length of the previous bone).
- Force Connect Children
Zu tun
- Automatic Bone Orientation
Zu tun
- Primary/Secondary Bone Axis
Zu tun
Export¶
- Path Mode
When referencing paths in exported files you may want some control as to the method used since absolute paths may only be correct on your own system. Relative paths, on the other hand, are more portable but mean that you have to keep your files grouped when moving about on your local file system. In some cases, the path doesn’t matter since the target application will search a set of predefined paths anyway so you have the option to strip the path too.
- Auto:
Uses relative paths for files which are in a subdirectory of the exported location, absolute for any directories outside that.
- Absolut:
Uses full paths.
- Relative:
Uses relative paths in every case (except when on a different drive on Windows).
- Match:
Uses relative / absolute paths based on the paths used in Blender.
- Strip Path:
Only write the filename and omit the path component.
- Kopieren:
Copy the file on exporting and reference it with a relative path.
- Embed Textures
Zu tun
- Batch Mode
When enabled, export each group or scene to a file.
- Group/Scene
Choose whether to batch export groups or scenes to files. Note, when Group/Scene is enabled, you cannot use the animation option Current Action since it uses scene data and groups are not attached to any scenes. Also note, when Group/Scene is enabled you must include the armature objects in the group for animated actions to work.
- Batch Own Directory
When enabled, each file is exported into its own directory, this is useful when using the Copy Images option. So each directory contains one model with all the images it uses. Note, this requires a full Python installation. If you do not have a full Python installation, this button will not be shown.
Include¶
- Selected Objects
Only export the selected objects. Otherwise export all objects in the scene. Note, this does not apply when batch exporting.
- Active Collection
Zu tun
- Object Types
Enable/Disable exporting of respective object types.
- Custom Properties
Zu tun
Transform¶
- Scale
Scale the exported data by this value. 10 is the default because this fits best with the scale most applications import FBX to.
- Apply Scaling
Zu tun
- Forward / Up
Since many applications use a different axis for ‚Up‘, these are axis conversions for Forward and Up axes – By mapping these to different axes you can convert rotations between applications default up and forward axes.
- Apply Unit
Zu tun
- Apply Transform
Zu tun
Geometry¶
- Smoothing
Export smoothing information.
If the importer supports custom split normals, using Normals Only is generally the most accurate.
- Normals Only:
Export only custom split normals, without writing any face or edge smoothing flags.
- Face:
Export smoothing using the face smoothing flags (Blender’s „smooth“ shading per face).
- Edge:
Export smoothing using edge sharpness. Sharp edges are used to define smoothing boundaries.
- Smoothing Groups:
Write face smoothing groups, which defines shading by grouping faces together—faces in the same group are shaded smoothly, while faces in different groups create hard edges. Useful for preserving shading in applications that rely on this method.
- Export Subdivision Surface
Zu tun
- Apply Modifiers
Export objects using the evaluated mesh, meaning the resulting mesh after all Modifiers have been calculated.
- Loose Edges
Zu tun
- Tangent Space
Zu tun
Armatures¶
Zu tun
- Armature FBXNode Type
Zu tun
- Only Deform Bones
Zu tun
- Add Leaf Bones
Zu tun
Bake Animation¶
Zu tun
- Key All Bones
Zu tun
- NLA Strips
Zu tun
- All Actions
Export all actions compatible with the selected armatures start/end times which are derived from the keyframe range of each action. When disabled only the currently assigned action is exported.
- Force Start/End Keying
Zu tun
- Sampling Rate
Zu tun
- Simplify
Zu tun
Compatibility¶
Importieren¶
Note that the importer is a new addition and lacks many features the exporter supports.
binary FBX files only.
Version 7.1 or newer.
Missing¶
Mesh: shape keys.
Export¶
NURBS surfaces, text3D and metaballs are converted to meshes at export time.
Missing¶
Some of the following features are missing because they are not supported by the FBX format, others may be added later.
Object instancing – exported objects do not share data, instanced objects will each be written with their own data.
Material textures
Vertex shape keys – FBX supports them but this exporter does not write them yet.
Animated fluid simulation – FBX does not support this kind of animation. You can however use the OBJ exporter to write a sequence of files.
Constraints – The result of using constraints is exported as a keyframe animation however the constraints themselves are not saved in the FBX.
Instanced objects – At the moment instanced objects are only written in static scenes (when animation is disabled).
