File Paths¶
Path Templates¶
Path templates substitute template expressions (written {abcd}, where
„abcd“ is a variable name) in a filepath when the path is used.
For example, if the currently open blend file is dance.blend and the render
output path is set to this:
//my_render_dir/{blend_name}.png
Then when rendering, Blender will treat the path as:
//my_render_dir/dance.png
With {blend_name} getting replaced by the dance from dance.blend.
This substitution happens internally at time of use (e.g. while rendering), so the template syntax will remain as-is in the path field.
Bemerkung
Currently path templates are only supported for the render output path in Scene properties and the output paths in the compositor’s File Output node. More filepaths will support templates in future releases.
Available Variables¶
The following variables are currently available in template expressions:
blend_name:The current blend file’s name (without the .blend).
fps:The frames per second of the current scene.
resolution_x / resolution_y:The x and y resolution of the rendered image. This factors in the resolution scale as well, so if the scene resolution is 1000x600 and the scale is 50%, then
resolution_xandresolution_ywill be 500 and 300, respectively.
The set of available variables will expand over time.
Syntax¶
A basic template expression simply wraps a variable name with curly braces:
Format Specifiers¶
Template expressions can also include a format specifier. Format specifiers instruct Blender how to format the substituted value. They are written after a separating colon, like this:
Format specifiers currently can only be used with variables that represent numerical values, not string values. The available format specifiers are:
dance_{fps:###}.png: format as an integer with at least 3 digits.dance_{fps:.###}.png: format as a floating point number with exactly 3 digits after the decimal point.dance_{fps:###.##}.png: format as a floating point number with at least 3 digits for the integer part and exactly 2 digits for the fractional part.
In all cases, the number of hash symbols (#) indicates the desired number of
digits.
For example, if the fps is 29.97, then:
dance_{fps:###}.png->dance_030.pngdance_{fps:.###}.png->dance_29.970.pngdance_{fps:###.##}.png-> ->dance_029.97.png
Note that the values are properly rounded for the given number of digits.
If no format specification is given, default formatting for the named variable is used (e.g. floating point for fps, integer for resolution).
Escape Sequences¶
Because { and } are used for template expressions in paths that support
them, when a literal { or } is desired in such a path they must be
escaped by writing them double:
{{translates to a single{in the final path.}}translates to a single}in the final path.
Zum Beispiel:
my_weird}}_{{path.png->my_weird}_{path.png//my_render_{{dir}}/{blend_name}.png->//my_render_{dir}/dance.png//my_render_dir/{{{blend_name}}}.png->//my_render_dir/{dance}.png
Errors¶
Paths that support templates can have template errors, which prevent the path from being processed.
For example, in the following path:
//my_render_dir/{blend_name.png
The expression {blend_name isn’t properly closed, which will result in an
error.
When there are template errors in a path, the path field will be highlighted red in the UI:
Hovering over the path field will pop up a tooltip that contains a list of the template errors encountered in that path:
Bemerkung
Depending on the path, template errors may prevent certain actions. For example, if there are errors in the render output path, then rendering an animation will fail with an error message indicating the path errors.
