Difference Key Node¶
This node produces a matte that isolates foreground content by comparing it with a reference background image.
Inputs¶
- Image 1
Contains foreground content against the background that is to be removed.
- Image 2
The reference background image.
- Tolerance
Where pixels match the reference background to within the specified threshold, the matte is made transparent.
- Falloff
Increase to make nearby pixels partially transparent producing a smoother blend along the edges.
Eigenschaften¶
This node has no properties.
Outputs¶
- Image
Image with its alpha channel adjusted for the keyed selection.
- Matte
A black-and-white alpha mask of the key.
