Separate Components Node¶
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Inputs¶
- Geometry
Standard geometry input.
Eigenschaften¶
This node has no properties.
Outputs¶
- Mesh
Mesh component of the input geometry.
- Kurve
Curve component of the input geometry.
- Point Cloud
Point cloud component of the input geometry.
- Volume
Volume component of the input geometry.
- Instances
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Realize Instances Node can be added to move the data from geometry instances to their corresponding outputs.
