Vector Rotate Node
../../../_images/render_shader-nodes_vector_vector-rotate_node.png
Vector Rotate Node.
The Vector Rotate Node provides the ability to rotate a vector around a pivot point (Center).
Inputs
Vector
Vector to be rotated.
Center
Point to rotate around.
Properties
Axis Angle
Rotates the vector around an axis defined by the Axis input vector and the amount of rotation is defined by the Angle input.
X, Y, Z Axis
Rotates the vector around the defined axis and the amount of rotation is defined by the Angle input.
Euler
Rotates the vector about the Center and defined by the Rotation input vector to control the amount of rotation on each axis.
Invert
Inverts the rotation angle.
Outputs
Vector
The rotated vector.
Exemples
../../../_images/render_shader-nodes_vector_vector-rotate_example.png
Vector Rotate node example.
