Map Range Node
Map Range Node.
The Map Range node remaps a value from a range to a target range.
Ingressi
Value/Vector
The input value or vector to be remapped.
From Min
The lower bound of the range to remap from.
From Max
The higher bound of the range to remap from.
To Min
The lower bound of the target range.
To Max
The higher bound of the target range.
Steps
The number of values allowed between To Min and To Max when using Stepped Linear interpolation. A higher value will give a smoother interpolation while lower values will progressively quantize the input.
Proprietà
Data Type
Map Range supports both Float and Vector data types. Changing the data type will also update the sockets to reflect the data type chosen.
Interpolation Type
The mathematical method used to transition between gaps in the numerical inputs.
Lineare
Linear interpolation between From Min and From Max values.
Stepped Linear
Stepped linear interpolation between From Min and From Max values.
Smooth Step
Smooth Hermite edge interpolation between From Min and From Max values.
Smoother Step
Smoother Hermite edge interpolation between From Min and From Max values.
Clamp
If enabled, the output is clamped to the target range.
Uscite
Result/Vector
The input value after remapping.
Esempi
The Noise Texture node outputs a value in the range [0, 1]. We can use the Map Range node to remap this value into the range [-1, 1].
../../../_images/render_shader-nodes_converter_map-range_example.jpg
Example of Map Range node.
