Random Value Node
![Random Value node.](../../../_images/node-types_FunctionNodeRandomValue.webp)
The Random Value node outputs a white noise like value as a Float, Integer, Vector, or Boolean field.
Ingressi
- Min
The minimum value of the range where random values are sampled from. This input is only available for Float, Integer, and Vector types.
- Max
The maximum value of the range where random values are sampled from. This input is only available for Float, Integer, and Vector types.
- Probability
The probability ratio for the random Boolean output to be True. This input is only available for Boolean types.
- ID
An ID to drive the random number generator seed. By default, this input uses the same value as of the ID Node, which is the
id
attribute of the context geometry if it exists, and otherwise the index.- Seme
A field to Seed the random number generator. This can be used to generate a different set of random values, even for two nodes with the same ID input.
Proprietà
- Data Type
- Float
The output will be a Float field.
- Integer
The output will be an Integer field.
- Vector
The output will be a Vector field.
- Boolean
The output will be a Boolean field.
Uscite
- Valore
Random values as a field.
