Instance Rotation Node
![Instance Rotation node.](../../../_images/node-types_GeometryNodeInputInstanceRotation.png)
The Instance Rotation outputs the XYZ Euler rotation of each top-level instance in the local space of the modifier object.
The Instances page contains more information about geometry instances.
Nota
Though rotations are often displayed in units of degrees in the spreadsheet or node editor, they are stored internally in radians, so this node outputs
Ingressi
Proprietà
This node has no properties.
Uscite
- Rotazione
Vector that indicates the rotation of each top-level instance in radians.
