Instance Scale Node
Instance Scale node.
The Instance Scale outputs the size of top-level instances on each axis in the local space of the modifier object.
The Instances page contains more information about geometry instances.
Ingressi
Proprietà
This node has no properties.
Uscite
Scala
Vector that indicates the scale of each top-level instance.
