Translate Instances Node
Translate Instances node.
The Translate Instances node moves top-level geometry instances in local or global space.
The Instances page contains more information about geometry instances.
Ingressi
Geometria
Standard geometry input.
Selezione
Boolean field used to determine if an instance will be translated.
Translation
The vector to translate the instances by.
Local Space
If enabled, the instances are translated relative to their initial rotation. Otherwise they are translated in the local space of the modifier object.
Proprietà
This node has no properties.
Uscite
Geometria
Standard geometry output.
