Gruppi di Nodi#
../../../_images/interface_controls_nodes_groups_example.png
Esempio di un gruppo di nodi.#
Grouping nodes can simplify a node tree by hiding away complexity and reusing repetitive parts.
Conceptually, node groups allow you to treat a set of nodes as though it were just one node. They’re similar to functions in programming: they can be reused (even in different node trees) and can be customized by changing their «parameters.»
As an example, say you created a «Wood» material that you would like to have in different colors. One way of doing this would be to duplicate the entire material for every color, but if you did that, you’d have to go over all those copies again if you later wanted to change the density of the grain lines. Instead, it would be better to move the nodes that define the wood look into a node group. Each material can then reuse this node group and just supply it with a color. If you then later want to change the grain line density, you only have to do it once inside the node group, rather than for every material.
Node groups can be nested (that is, node groups can contain other node groups).
Nota
I gruppi di nodi ricorsivi sono vietati per tutti i sistemi di nodi attuali per impedire la ricorsione infinita. Un gruppo di nodi non può mai contenere se stesso (o un altro gruppo che lo contiene).
Suggerimento
Like all data-blocks, node groups with names that start with . are normally hidden from lists and menus and can only be accessed through search. This can be useful for node asset authors to hide their internal sub-groups from the final user.
When a node group is created, new Group Input and Group Output nodes are generated to represent the data flow into and out of the group. Furthermore connections to input sockets coming from unselected nodes will become attached to new sockets on the Group Input node. Similarly, outgoing connections to input sockets of unselected nodes will become attached to the new Group Output node.
If you want to pass an additional parameter into the group, a socket must be added to the Group Input node. To do this, drag a connection from the hollow socket on the right side of the Group Input node to the desired input socket on the node requiring an input. The process is similar for the Group Output regarding data you want to be made available outside the group.
Proprietà#
Gruppo#
Riferimento
Pannello:
Sidebar ‣ Group ‣ Group
../../../_images/interface_controls_nodes_groups_interface-group-panel.png
The Group panel.#
This panel contains properties that relate the group node such as it’s name and look.
Nome
The name of node as displayed in the Titolo.
Descrizione
The message displayed when hovering over the Titolo or in add menus.
Color Tag
Color tag of the node group which influences the header color.
Usage Geometry Nodes#
This panel is only visible in the Geometry Node Editor.
Modifier
The node group is used as a Geometry Nodes Modifier.
Strumento
The node group is used as a Node-Based Tools.
Group Sockets#
Riferimento
Pannello:
Sidebar ‣ Group ‣ Group Sockets
../../../_images/interface_controls_nodes_groups_interface-group_sockets_panel.png
The Group Sockets panel.#
This panel is used to add, remove, reorder, and edit the sockets of the group’s input and output.
Socket List
A List View of all inputs, outputs and panels.
Here you can name the socket which is displayed in the node’s interface.
Descrizione
The message displayed when hovering over socket properties.
Closed by Default Panels
Panel is closed by default on new nodes.
Default
The value to use when nothing is connected to the socket.
Min, Max
The minimum and maximum value for the UI button shown in the node interface. Note, this is not a minimum or maximum for the data that can pass through the node. If a socket passes a higher value than the maximum, it will still pass into the node unchanged.
Default Input
Input to use when the socket is unconnected. Requires Hide Value to be enabled.
Hide Value
Hide the socket value even when the socket is not connected.
Hide in Modifier
Don’t show the input value in the geometry nodes modifier interface. This allows the input to be used in the context of a node group but not as a modifier input.
This option is only available for geometry nodes and only for input sockets.
Single Value
Only allow single value inputs rather than Campi.
Creare Gruppo#
Riferimento
Menù:
Nodo ‣ Crea Gruppo
Scorciatoia:
Ctrl-G
To create a node group, select the nodes you want to include, then press Ctrl-G or click Group ‣ Make Group. A node group will have a green title bar. All selected nodes will now be contained within the node group. Default naming for the node group is «NodeGroup», «NodeGroup.001» etc. There is a name field in the node group you can click into to change the name of the group. Change the name of the node group to something meaningful.
When appending node groups from one blend-file to another, Blender does not make a distinction between material node groups or composite node groups. So it is recommended to use some naming convention that will allow you to distinguish between the two types.
Suggerimento
The «Add» menu of each node editor contains an «Output» category with node types such as «Material Output.» These node types should not be confused with the «Group Output» node found in node groups, and should not be used in node groups either (only in the top-level node tree).
Insert Into Group#
Riferimento
Menù:
Node ‣ Insert Into Group
Moves the selected nodes into the active group node. To use, select a set of nodes, ending with the destination group node, then, running the operation will move those nodes into that group. The moved nodes are collected into a group of their own to preserve their connection context, having their own group input and output nodes. The group’s existing input and output nodes are updated with new sockets, if any, from the new nodes. The node group must be edited to contain a single Group Input and a single Group Output node.
Modifica Gruppo#
Riferimento
Menù:
Nodo ‣ Modifica Gruppo
Intestazione:
Vai all’Albero dei Nodi Principali
Scorciatoia:
Tab, Ctrl-Tab
With a node group selected, press Tab to move into it and see its content. Press Tab again (or Ctrl-Tab) to leave the group and go back to its parent, which could be the top-level node tree or another node group. You can refer to the breadcrumbs in the top left corner of the node editor to see where you are in the hierarchy.
../../../_images/render_cycles_optimizations_reducing-noise_glass-group.png
Esempio di un gruppo di nodi espanso.#
Separa#
Riferimento
Menù:
Node ‣ Ungroup
Scorciatoia:
Ctrl-Alt-G
Removes the group and places the individual nodes into your editor workspace. No internal connections are lost, and now you can link internal nodes to other nodes in your workspace.
Separa P
Separa i nodi selezionati dal gruppo di nodi.
Copia
Copia nella struttura del nodo padre, mantieni intatto il gruppo.
Muovi
Passa all’albero del nodo principale, rimuovilo dal gruppo.
Reusing Node Groups#
Riferimento
Menù:
Add ‣ Group
Scorciatoia:
Shift-A
Existing node groups can be placed again after they’re initially defined, be it in the same node tree or a different one. It’s also possible to import node groups from a different blend-file using File ‣ Link/Append.
