Join Geometry Node#
The Join Geometry node merges separately generated geometries into a single one. If the geometry inputs contain different types of data, the output will also contain different data types.
Nota
The node cannot handle the case when more than one geometry input has a volume component.
Materials#
When multiple mesh inputs contain different materials, the material slots from each mesh geometry are merged so that the output mesh will contain all the input materials.
Attributes#
When merging attributes from multiple geometry inputs, the highest complexity data type is chosen
for the output attribute. In other words, if a weight attribute has a Boolean type on one geometry input
and a vector data type on another geometry, the weight attribute on the output geometry will have
a vector data type. The same heuristic is used for attribute domains, the domain with the most information
will be used for the output.
Avvertimento
Like other geometry nodes, this node always outputs generic typed attributes. So instead of a Vertex Group attribute, it will create a «Float» attribute on the result, and it will create a generic 2D vector attribute instead of a special «UV Map» attribute. Some other areas of Blender don’t properly handle generic attributes in version 3.0.
Custom face corner normals are also not transferred currently.
Ingressi#
- Geometria
Geometry that will be joined. Multiple inputs are allowed. When the node is muted, only the first link will be passed through.
Proprietà#
This node has no properties.
Output#
- Geometria
Standard geometry output.
