Menu Switch Node#
The Menu Switch node outputs one of its inputs depending on a menu selection. Only the input that is passed through the node is computed.
Vedi anche
Ingressi#
- Menù
Determines which of the input options below will be passed through.
- Item Inputs
One input is created for every menu entry. The input is used when the matching option is selected. Items can be renamed by Ctrl-LMB on the socket name or in the nodes Properties panel.
Proprietà#
- Tipo
Determines the type of the data that is handled by the node.
Uscite#
- Output
One of the inputs without any modifications.
