Set Instance Transform Node
Set Instance Transform node.
The Set Instance Transform node Transforms geometry instances using a Transformation Matrix.
The Instances page contains more information about geometry instances.
Ingressi
Instances
Standard geometry input.
Selezione
Boolean field used to determine if an instance will be rotated.
Trasforma
The transformation matrix to translate, rotate, and scale individual instances.
Uscite
Instances
Standard geometry output.
