Ivy Gen
Based on the wonderful code by Thomas Luft and his original IvyGen program.
Original Blender port by testscreenings, further advances by PKHG and TrumanBlending.
![../../_images/addons_add-curve_ivy-gen_example.jpg](../../_images/addons_add-curve_ivy-gen_example.jpg)
Aktivácia
Otvorte Blender a prejdite
.Click Add Curve then Ivy Gen to enable the script.
Rozhranie
![../../_images/addons_add-curve_ivy-gen_ui.jpg](../../_images/addons_add-curve_ivy-gen_ui.jpg)
Located in the
.Located in the
.The Update Ivy operator is separate from the main menu and appears in the 3D Viewport. You can adjust settings in the panel and press the Update button to update parameters.
Instructions
Select the object you want to grow ivy on.
Enter Edit Mode and select a vertex that you want the ivy to spawn from.
Snap the cursor to the selected vertex.
Enter Object Mode and with the object selected:
adjust settings and choose Add New Ivy.
The Add Default Ivy operator will use the default parameters during creation. This will generate your initial Ivy Curve and Leaves. From here you can access the Ivy menu in the Sidebar. I suggest to make small changes and then press Update Ivy in the 3D Viewport operator.
Referencia
- Kategória:
Pridať krivku
- Popis:
Adds generated ivy to a mesh object starting at the 3D Cursor.
- Poloha:
- Súbor:
add_curve_ivygen.py
- Autor:
testscreenings, PKHG, TrumanBlending
- Udržiavateľ:
Vladimir Spivak (cwolf3d)
- Licencia:
GPL
- Úroveň podpory:
Community
- Poznámka:
Tento doplnok je súčasťou balíka Blender.
