Mesh to Volume Node
The Mesh to Volume node creates a fog volumes based on the shape of a mesh. The volume is created with a grid of the name «density».
Inputs – Уводи
- Mesh – Сіть
Standard Mesh input.
- Щільність – Density
Value of voxels inside the generated fog volume.
- Voxel Amount
Specify the approximate number of voxels along the diagonal.
- Розмір Вокселя – Voxel Size
Specify the voxel side length.
- Exterior Band Width
The maximum distance of the included voxels to the surface on the outside of the mesh.
- Interior Band Width
The maximum distance of the included voxels to the surface on the inside of the mesh. Activating Fill Volume is similar to increasing the interior band width to a high number.
- Fill Volume
The entire enclosed volume or otherwise only the voxels close to the surface will get a density greater than zero. This setting is only used when the mesh object is Manifold.
Properties – Властивості
- Роздільність – Resolution
How the voxel size is specified.
- Amount – Величина
- Size – Розмір
Specify the voxel side length. It is recommended to be careful when tweaking this value, because small changes can have a large effect on the processing time.
Outputs – Виводи
- Volume – Об’єм
The generated volume grid.
