Sample UV Surface Node
The Sample UV Surface node finds values on a mesh’s surface at specific UV locations. Internally the process is a «reverse UV lookup» from a location in 2D space. The node then finds the face that corresponds to each UV coordinate, and the location within that face.
Попередження
Because of the node’s method of computatation, the UV map should not have any overlapping faces. If the UV map is sampled at a location with no faces or overlapping faces, the node will output the default value for the data type, which is zeros for most types.
Inputs – Уводи
- Mesh – Сіть
A geometry containing the mesh with a UV map for sampling.
- Value – Значення
A field to evaluate on the target Mesh geometry for later sampling at the surface positions.
- Source UV Map
The mesh UV map to sample, evaluated on the Mesh input. Should not have overlapping faces.
- Sample UV
The coordinates to sample within the UV map.
Properties – Властивості
- Тип Даних – Data Type
The data type to use for the retrieved values.
Outputs – Виводи
- Value – Значення
The data retrieved and interpolated from the Mesh geometry, mapped based on the node’s settings and inputs.
- Is Valid
Whether the node could find a single face to sample at the UV coordinate.
