Phân Tách Xương (Separate Components Node)
../../../_images/modeling_geometry-nodes_geometry_separate-components_node.png
The Separate Components node.
The Separate Components node splits a geometry into a separate output for each type of data in the geometry.
Đầu Vào (Inputs)
Hình Học (Geometry)
Standard geometry input.
Tính Chất (Properties)
Nút này không có Tính Chất nào cả.
Đầu Ra (Outputs)
Mesh (Khung Lưới)
Mesh component of the input geometry.
Point Cloud (Mây Điểm Chấm)
Point cloud component of the input geometry.
Curve (Đường Cong)
Curve component of the input geometry.
Âm Lượng (Volume)
Volume component of the input geometry.
Thực Thể (Instances)
Instances component of the input geometry. Even if the instances contain geometry data with one of the other types, all instances will be added to this output. A Mô Hình Khoảng Cách -- Distance Model (Realize Instances Node) can be added to move the data from geometry instances to their corresponding outputs.
