混合属性¶
Attribute Mix Node.¶
Mix attributes to creates to create a new attribute.
输入¶
- 几何数据(Geometry)
Standard geometry input.
- A, B
The first and second input to the mix operation. This can be an attribute name or a value.
- 结果
Name of the attribute where the computed result is stored. The output attribute type is Color by default. When the result attribute exists already, its type is not changed.
属性¶
- 混合类型
Operation that is performed on the inputs.
- Factor A, B
Input type for the corresponding socket.
输出¶
- 几何数据(Geometry)
Standard geometry output.
