属性随机化¶
Attribute Randomize Node.¶
The Attribute Randomize node replaces the values in an attribute with random values within the given range.
输入¶
- 几何数据(Geometry)
Standard geometry input.
- 属性
Name of the attribute to fill with random values. If there is no attribute with the given name, a new one is created.
- 最小值
The random value will be at least those values.
- 最大值
The random values will be no more than those values.
- 随机种
Seed to change the random sequence.
属性¶
- 类型
Type of data stored in the attribute.
- 浮动
Single (floating-point) value.
- 矢量
Array of three (floating-point) values.
- 布尔
A true or false value.
输出¶
- 几何数据(Geometry)
Standard geometry output.
