Edge Neighbors Node
../../../_images/modeling_geometry-nodes_input_edge-neighbors_node.png
Edge Neighbors Node.
The Edge Neighbors node outputs topology information relating to each edge of a mesh.
输入
该节点没有输入项。
属性
这个节点没有属性。
输出
Face Count
The number of faces that use the edge as one of their sides. When the value is one, the edge is a non-manifold boundary edge. Alternatively, when the value is zero, the edge is a loose edge, not used by any faces.
示例
../../../_images/modeling_geometry-nodes_input_edge-vertices_boundary.png
Using the Face Count output to create a curve on a mesh's boundary edges.
