Split Edges Node
../../../_images/modeling_geometry-nodes_mesh_split-edges_node.png
The Split Edges node.
Like the 拆边修改器, the Split Edges node splits and duplicates edges within a mesh, breaking 'links' between faces around those split edges.
输入
网格
Standard geometry input.
选择
A standard Boolean selection input to determine which edges will be split.
Note
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
属性
这个节点没有属性。
输出
网格
Standard geometry output.
