ANT Landscape#
This add-on creates landscapes and planets using various noise types. A.N.T. stands for Another Noise Tool.
Aktivierung#
Öffne Blender und gehe zu den Preferences, und dort zum Add-ons Reiter.
Click Add Mesh then A.N.T. Landscape to enable the script.
Interface#
Located in the
menu.Located in the
tab.Anweisungen#
After creating your landscape mesh there are three main areas in the Adjust Last Operation panel to design your mesh.
Main Settings: Object and mesh related settings like size and subdivisions.
Noise Settings: Noise related settings that give shape to your terrain.
Displace Settings: Settings for terrain height and edge falloff.
Landscape Panel#
- Landscape
Landscape will create the mesh and add several panels and tools to the Sidebar.
Landscape Tools#
- Mesh Displace
Displace selected mesh vertices along normal or X, Y, Z direction.
- Weight from Slope
Generates a weighted vertex group slope map based on the Z normal value.
- Landscape Eroder
Apply various kinds of erosion to an A.N.T. Landscape grid, also available in the Weights menu in Weight Paint Mode.
Landscape Main#
Here we can adjust the main settings and regenerate the mesh.
Smooth the mesh, Triangulate the mesh, Rename and add materials that you have in your blend-file.
Landscape Noise#
Here we can adjust the noise settings and refresh only those settings.
There are many settings and noise types that allow you to customize your landscape.
Landscape Displace#
Here we can adjust the displacement settings and refresh only those settings.
Adjust Height, Falloff and Strata in this section.
Nutzung#
Referenz
- Kategorie:
Add Mesh
- Beschreibung:
Another Noise Tool: Landscape, erosion and displace.
- Datei:
ant_landscape folder
- Autor:
Jimmy Hazevoet
- Maintainer:
- Lizenz:
*GPL*
- Support Level:
Community
- Beachte:
Dieses Add-on ist gebündelt mit Blender.
