Vector Curves Node¶
Vector Curves Node.
The Vector Curves node maps an input vector components to a curve.
Use this curve node to slow things down or speed them up from the original scene.
Inputs¶
In the shader context the node also has an additional Factor property.
- Factor
- Controls the amount of influence the node exerts on the output vector.
- Vector
- Standard vector input.
Properties¶
- Channel
- X, Y, Z
- Curve
- For the curve controls see: Curve widget.
Outputs¶
- Vector
- Standard vector output.
