Index Switch Node¶
The Index Switch node outputs one of its inputs depending on an index value. Only the input that is passed through the node is computed.
Katso myös
The Menu Switch Node is similar but it exposes the choices as a menu.
Inputs¶
- Index
Determines which of the input options below will be passed through.
- Item Inputs
One input is created for every menu entry. The input is used when the matching option is selected.
Properties¶
- Type
Determines the type of the data that is handled by the node.
Outputs¶
- Output
One of the inputs without any modifications.
