Random Value Node¶
The Random Value node outputs a white noise like value as a Float, Integer, Vector, or Boolean field.
Inputs¶
- Min
The minimum value of the range where random values are sampled from. This input is only available for Float, Integer, and Vector types.
- Max
The maximum value of the range where random values are sampled from. This input is only available for Float, Integer, and Vector types.
- Probability
The probability ratio for the random Boolean output to be True. This input is only available for Boolean types.
- ID
An ID to drive the random number generator seed. By default, this input uses the same value as of the ID Node, which is the
id
attribute of the context geometry if it exists, and otherwise the index.Vihje
Single Random Value
By default, the random value node generates a value for each unique index. If a single random value is desired, connect a single value (such as an Integer Node ) to the ID input.
- Seed
A field to Seed the random number generator. This can be used to generate a different set of random values, even for two nodes with the same ID input.
Properties¶
- Data Type
- Float:
The output will be a Float field.
- Integer:
The output will be an Integer field.
- Vector:
The output will be a Vector field.
- Boolean:
The output will be a Boolean field.
Outputs¶
- Value
Random values as a field.
