Transfer Attribute Node
The Transfer Attribute node retrieves values from a source geometry and provides them as a field, so they can be used anywhere.
Inputs
- Source
La géométrie à partir de laquelle récupérer l’attribut.
Note
This node only supports instances in the source geometry when the Mapping method is set to Index.
- Attribute
Champ à évaluer sur la géométrie Source à utiliser avec la méthode de transfert.
- Source Position
The position to start from when finding the closest location on the source mesh or point cloud. Used in the Nearest Face Interpolated and Nearest modes. By default, this is the same as if the Nœud Position was connected.
- Index
Which index to use when retrieving the data from the input field in Index mode. By default, the index is used, meaning that the data from the source attribute is copied directly to the output. However, a different index can be connected, resulting in a « shuffling » of the values. Indices that are either too large or below 0 are clamped.
Astuce
To retrieve a single attribute value instead of a field, a single integer input or the Nœud Integer can be connected to this socket.
Properties
- Domaine
Le domaine d’attribut à partir duquel l’attribut est transféré, ou en d’autres termes, le domaine d’attribut utilisé pour évaluer l’entrée Attribute. Par exemple, il est possible de transférer des données des faces d’une géométrie vers les points d’une autre.
- Mapping
How elements from the destination geometry are mapped to the output.
- Index
Copy the attribute data from the value at the input index. In this mode, the source geometry can consist of a mesh, point cloud, or curve. The matching component type from the context will be chosen if possible, otherwise a component will be chosen in that order.
- Nearest Face Interpolated
Transfer the attribute from the nearest point from anywhere on the surface. Non-face attributes are interpolated across the surface (edge attributes are not supported yet). Loose points and edges are ignored.
- Nearest
Transfer the attribute from the nearest element (with a domain chosen by the Domain input). No interpolation is done.
Outputs
- Attribute
The data retrieved from the Source geometry, mapped based on the node’s settings and inputs.
Exemples
Transferring the position of vertices from a different object’s geometry, assuming that they have the same number of points.
