Spreadsheet
The Spreadsheet editor is used to inspect the geometry attributes of the active object, typically in order to debug geometry nodes.
../_images/editors_spreadsheet_interface.png
The Spreadsheet editor.
Regione Principale
The main region displays the attribute data in a spreadsheet format. Each column corresponds to an attribute or data property, and each row represents an element such as a vertex, face, spline, or instance.
Column names and row indices remain visible while scrolling both vertically and horizontally.
  • Columns can be resized by clicking and dragging the vertical line between columns.
  • Double clicking the vertical line automatically sizes the column to fit the content.
  • Columns can be reordered by clicking and dragging the column header.
Nota
Tooltips give more detail about the value, depending on the type. For example, Byte Color attributes are displayed as scene linear floats, but the actual integer values are displayed when hovering over the float values, and Matrix attribute values are only displayed in tooltips.
Data Set Region
Located on the left, this region controls which data is displayed in the spreadsheet.
Context Path
Displays the active object name in the panel header.
Clicking one of the arrows between the names to hide the modifier.
Clicking the icon locks the Spreadsheet editor to the currently active object and data path, keeping it visible even if you select another object. Click again to unlock.
Object Evaluation State
Defines which state of the object’s data is displayed:
Evaluated:
Shows data with all modifiers applied.
Original:
Shows the original object data, without modifiers.
Viewer Node:
Displays data from the active Viewer Node in Geometry Nodes.
You can also toggle between Evaluated and Viewer Node by clicking the / icon in the Viewer node’s header.
Viewer Path
Visible when Object Evaluation State is set to Viewer Node.
Shows the path from the modifier to the active viewer node. If the viewer node is nested inside group nodes, each group will appear in the path.
Geometria
Lets you browse nested geometries (e.g., a mesh inside an instance or a geometry collection).
Domain
Lets you choose the attribute domain to display, such as mesh vertices or curve splines.
The number of elements in each domain is shown next to its entry.
Barra di stato
The status bar shows how many rows and columns there are, and how many rows remain after filtering.
