Bounding Box¶
The Bounding Box node.¶
The Bounding Box node creates a cube with the minimum volume that encapsulates the geometry of the input. The node also can output the vector positions of the bounding dimensions.
Inputs¶
- Geometria
Entrada padrão de geometria.
Properties¶
Saídas¶
- Geometria
The resulting box or cube to encapsulate the input geometry.
- Mínimo
The coordinates corresponding to the cubes -X, -Y, -Z position values, i.e. how far the box extends in each of the negative axes directions.
- Máximo
The coordinates corresponding to the cubes +X, +Y, +Z position values. i.e. how far the box extends in each of the positive axes directions.
