Join Geometry¶
The Join Geometry node merges separately generated pieces of geometry into a single one. If the inputted pieces contain different types of geometry, the output will contain multiple types of geometry.
The Join Geometry node.¶
Nota
O nó não pode lidar o caso quando mais de uma entrada de geometria tem um componente volumétrico.
Inputs¶
- Geometria
Pieces of geometry that will be joined. Multiple inputs are allowed. When the node is muted, only the first link will be passed through.
Properties¶
Saída¶
- Geometria
Saída padrão de geometria.
