Boolean Math Node
../../../_images/modeling_geometry-nodes_utilities_boolean-math_node.png
Boolean Math Node.
The Boolean Math node performs a basic logical operation on its inputs.
Inputs – Уводи
Boolean – Булів
Two standard Boolean inputs.
Properties – Властивості
Mode – Режим
And
True when both inputs are true. (AND)
Or
True when at least one input is true. (OR)
Not – Не
Opposite of the input. (NOT)
Not And
(True when at least one input is false. NAND)
Nor
True when both inputs are false. (NOR)
Equal
True when both inputs are equal. Also known as «exclusive nor». (XNOR)
Not Equal
(XOR) True when both inputs are different. Also known as «exclusive or».
Imply
True unless the first input is true and the second is false. (IMPLY)
Subtract – Відняття
True when the first input is true and the second is false. Also known as «»not imply». (NIMPLY)
Вивід – Output
Boolean – Булів
Standard Boolean output.
