Float To Integer Node
../../../_images/modeling_geometry-nodes_utilities_float-to-int_node.png
Float To Integer Node.
The Float To Integer node takes a single floating point number input and converts it to an integer with a choice of methods.
Inputs – Уводи
Float
Standard float value input.
Properties – Властивості
Rounding Mode
Round – Округлення
Outputs the closest integer to Float, rounding either up or down based on the value.
Floor – Підлога
Outputs the closest integer less than Float, always rounding down.
Ceiling
Outputs the closest integer greater than Float, always rounding up.
Truncate – Урізання
Outputs the closest integer between Float and zero. For positive numbers, acts like Floor. For negative numbers, acts as Ceiling.
Вивід – Output
Результат
Standard integer output.
Examples – Приклади
Input Value
Round – Округлення
Floor – Підлога
Ceiling
Truncate – Урізання
-69.6574
-70
-70
-69
-69
-3.14159
-3
-4
-3
-3
-1.5
-2
-2
-1
-1
1.5
2
1
2
1
3.14159
3
3
4
3
69.6574
70
69
70
69
