Attribute Math¶
Modify an attribute with a math operation.
The Attribute Math Node.¶
Inputs¶
- Geometry
Standard geometry input.
- A, B
The first and second input to the math operation. This is either an attribute name or numeric value.
- Result
Name of the attribute where the computed result it stored. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
Properties¶
- Operation
The math function to perform.
Ghi chú
Attributes are converted implicitly to the float data type.
- Type A, B
- Attribute
The input is a text field that expects an attribute name.
- Float
The input is a number field.
Output¶
- Geometry
Standard geometry output.
