网格 转 体积
网格转体积节点。
The Mesh to Volume node creates a fog volumes based on the shape of a mesh. The volume is created with a grid of the name "density".
输入
网格
标准法向输入。
密度
生成的雾量内的体素值。
体素数量
指定沿对角线的体素的近似数量。
体素大小
指定体素边长。
Exterior Band Width
The maximum distance of the included voxels to the surface on the outside of the mesh.
内部带宽
The maximum distance of the included voxels to the surface on the inside of the mesh. Activating Fill Volume is similar to increasing the interior band width to a high number.
Fill Volume
The entire enclosed volume or otherwise only the voxels close to the surface will get a density greater than zero. This setting is only used when the mesh object is Manifold.
属性
分辨率
如何定义体素大小。
数量
指定沿对角线的体素的近似数量。
尺寸
指定体素侧长度。建议调整此值时要小心,因为小小的变化可能会对处理时间产生很大影响。
输出
体积/音量
生成的体积栅格。
