Boolean Math Node
Boolean Math Node.
The Boolean Math node performs a basic logical operation on its inputs.
Ingressi
- Boolean
Two standard Boolean inputs.
Proprietà
- Modalità
- And
True when both inputs are true. (AND)
- Or
True when at least one input is true. (OR)
- Not
Opposite of the input. (NOT)
- Not And
(True when at least one input is false. NAND)
- Nor
True when both inputs are false. (NOR)
- Equal
True when both inputs are equal. Also known as «exclusive nor». (XNOR)
- Not Equal
(XOR) True when both inputs are different. Also known as «exclusive or».
- Imply
True unless the first input is true and the second is false. (IMPLY)
- Sottrai
True when the first input is true and the second is false. Also known as «»not imply». (NIMPLY)
Output
- Boolean
Standard Boolean output.
