Float To Integer Node
../../../_images/modeling_geometry-nodes_utilities_float-to-int_node.png
Float To Integer Node.
The Float To Integer node takes a single floating point number input and converts it to an integer with a choice of methods.
Ingressi
Float
Standard float value input.
Proprietà
Rounding Mode
Round
Outputs the closest integer to Float, rounding either up or down based on the value.
Piano
Outputs the closest integer less than Float, always rounding down.
Ceiling
Outputs the closest integer greater than Float, always rounding up.
Truncate
Outputs the closest integer between Float and zero. For positive numbers, acts like Floor. For negative numbers, acts as Ceiling.
Output
Result
Standard integer output.
Esempi
Input Value
Round
Piano
Ceiling
Truncate
-69.6574
-70
-70
-69
-69
-3.14159
-3
-4
-3
-3
-1.5
-2
-2
-1
-1
1.5
2
1
2
1
3.14159
3
3
4
3
69.6574
70
69
70
69
