Field at Index Node
The Field at Index node allows accessing data of other elements in the context geometry. It is similar to the Transfer Attribute Node in Index mode. The main difference is that this node does not require a geometry input, because the geometry from the field context is used.
Ingressi
- Index
The index of the element in the selected domain to retrieve data from, i.e. «the fourth face», or «the first control point».
- Valore
The field to retrieve data from.
Proprietà
- Domain
The attribute domain used for accumulation and for evaluation of the Value input. If the
Output
- Valore
The value of the input field at the given index.
