Float Curve
../../../_images/render_shader-nodes_converter_float-curve_node.jpg
Float Curve node.
The Float Curve node maps an input float to a curve and outputs a float value.
Ingressi
Fattore
Controls the amount of influence the node exerts on the output value.
Valore
Standard float input.
Proprietà
Curva
For the curve controls see: Curve widget.
Uscite
Float
Standard float output.
